Fuel system needed for 700rwhp?
Old Sep 12, 2004 | 08:57 PM
BOOSTAT4500's Avatar
Default Fuel system needed for 700rwhp?
I'm running a 408 with a d-1sc at about 7lbs. Right now I have a 255L inline pump and a KB boost-a-pump added on. I start dropping pressure at about 4500rpm and 500rwhp. The tuner says a bigger in-tank ( single 255L ) is all I need to add. Right now I'm only trying for 600rwhp but plan on adding boost this winter. What do I need to support 700rwhp? How much will the stock lines and rail support? Thanks!
Old Sep 12, 2004 | 10:46 PM
PurEvl's Avatar
fuel
Walbro 340l intank -single
-8 feed to Nasty fuel rail's
Aeromotive regulator set at 52 PSI -line off
-6 return
60lb Motrons
Old Sep 13, 2004 | 11:55 AM
MEAN LT1's Avatar
Several people have have ran dual intank pumps using Walbro high pressure fuel pumps. One stays on while the other kick in via a hobbs switch and boosts fuel pressure as needed.
Old Sep 13, 2004 | 02:55 PM
O yeah, I also have 60lbs. mototrons. Are the dual setups sold as a kit with the switch or are they custom deals? Would it work to just wire them both on at all times?
Old Sep 13, 2004 | 03:06 PM
69firebird's Avatar
well I have a sumped tank
aerotmotive a1000 fuel pump
-8 up into speed inc rails
-6 into CAS regulator
stock lines back to sump
hoping im not going to have hte cavatating problems most do with the a1000, if so Ill add a fuel cooler to help correct
need to also get the voltage regulator from aeromotive
ed
Old Sep 13, 2004 | 03:31 PM
cablebandit's Avatar
I think you need dual walbro pumps. You can do this yourself like I did or get one from Racetronix. You won't need a B_A_P with dual walbros. The mototron 60# are good for well over 700rwhp as shown by Mightymouse.
Old Sep 13, 2004 | 04:55 PM
MEAN LT1's Avatar
Yes, racetronix would be the compnay to get ahold of for the dual walbro setup.
Old Sep 13, 2004 | 06:01 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
700RWHP requires a well designed DP system.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Sep 13, 2004 | 06:30 PM
Slowhawk's Avatar
LS1Tech Sponsor
Your problem is the stock fuel lines/rails. 5Liters car has a feed/return setup with regulator.Stopped his fuel problem The stock feed line just can't hold enough fuel.
Old Sep 13, 2004 | 06:55 PM
NA$TY-TA's Avatar
The HP we see with a blower and a turbo are 2 different things.... with the same Injectors...... A turbo is more efficent then a blower and the HP you see at the rear wheels might be the same but the HP the motor is eating is not seen with a turbo like it is with a blower...... The motor is turning the blower and is taking HP to do that so the injector will need to be bigger with a blower motor to reach the same HP as a turbo........
Kyle
Old Sep 13, 2004 | 10:11 PM
Racetronix's Avatar
LS1TECH Sponsor
No, it is the regulation point.
Read from top to bottom and learn:
https://ls1tech.com/forums/showthrea...ght=Racetronix
__________________
>WEB SITE<
Old Sep 13, 2004 | 10:44 PM
Slowhawk's Avatar
LS1Tech Sponsor
Sorry I learned by running into the problem then fixing it with what we did
I'm sure your way works great,just posted how we beat the problem,now running lower fuel pressure with some room to spare
Old Sep 13, 2004 | 11:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Dual intanks sound like a good idea.
Or you could run aftermarket stuff for the rails, fuel line, regulator and tank.
I currently run a Speed Inc. gas tank and some aftermarket rails. I run one external Weldon 2025 pump right now. I am probably going to dual Bosch pumps from Speed Inc. very soon. Those would again be dual external pumps.
Old Sep 14, 2004 | 12:03 AM
Racetronix's Avatar
LS1TECH Sponsor
Yes, every Weldon pump should come with a bottle of Asprin and ear plugs.
They work well though.
__________________
>WEB SITE<
Old Sep 14, 2004 | 01:57 PM
ls1290's Avatar
Dumb Ass Vette Moderator
- Racetronix C5 Intank Fuel Pump
- Kenny Bell Boost-A-Pump
- -8an send line
- -6an return line
- CB Performance Hard Line Adapters
- Speed Inc Billet Fuel Rails
- CAS Billet Fuel Regulator
- 75# RC Engineering HI Fuel Injectors
Good for a 1000 rwhp.
Old Sep 14, 2004 | 02:20 PM
MIGHTYMOUSE's Avatar
home made twin in tank gss340's
-8 to speed inc BIG filter
-8 up to speed inc rails
-8 crossover
-6 to cas regulator
stock pressure line back to the stock tank
mototron 60's set to 50psi with the vaccum off & goes up 1psi/psi boost
*edit* both pumps run all the time off of one radio shack 30A relay w/ fused link to the accessory terminal under hood. stock pump power wire triggers relay to ON.
Old Sep 14, 2004 | 02:42 PM
David, next time you are under that car, check that relay. Mine melted eventually running both pumps from one relay. Could just be me but would hate for ya to get stuck because of it. I could only tell because one of the "legs" wobbled. I was alerted to the problem because the pumps wouldn't turn off when I removed the key The B_A_P comes in the one/two pump flavors...the two pump model is a 40amp unit and the one pump model is 20 amp I believe.....something to think about.
-8 crossover
-6 to cas regulator
Old Sep 14, 2004 | 03:40 PM
has been like this for nearing a year now.. i switched from a two relay set up because one of them melted.. turned out to be a bad ground... something to think about
Old Sep 14, 2004 | 04:53 PM
AHA!! Maybe you are right......... but I did check the ground When are you going to run mid 9s....I see you got the mph for it...something new to think about
Racetronix's Avatar
LS1TECH Sponsor
Either a cheap relay or a non-Weatherpack version. We have never had a problem like this with the Siemens (now Tyco) 40 amp W/P relays.
Our DP harness has a dedicated relay and fuse for each pump so they can be controlled independently.
__________________
>WEB SITE<
