Race Fuel users: fast question plz
Old Sep 14, 2004 | 05:07 AM
Solid346's Avatar
Default Race Fuel users: fast question plz
i just want to know if anyone is using C-16 fuel, is it leaded or unleaded. and is it possible to mix leaded with unleaded gas togather
thanks
Old Sep 14, 2004 | 05:27 AM
BTL FED's Avatar
C16 is leaded, Yes I BELIEVE you can mix them, but remember leaded gas kills o2's fast
Old Sep 14, 2004 | 08:52 AM
Solid346's Avatar
thanks for the input. can anyone back this point about mixing leaded and unleaded. and how would escape kiling my o2 sensors, and will it hurt my preformance if the o2's are burned
Old Sep 14, 2004 | 10:49 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
thanks
-I have used it.
-I have a FAST.
-Fuel manufacturers do not reccomend mixing gases because they have different gravities, but some of us FI guys have been doing it for a while with no apparent ill effects.
-You may want to look into the Denso 02 sensors and see if they are more lead resistant like folks say.
Old Sep 14, 2004 | 08:51 PM
red ws6 99's Avatar
Destroys cats as well. Won't affect your WOT performance much since the computer is not running of them at WOT. Will screw up your idle and cruising though.
Gary
Old Sep 14, 2004 | 09:03 PM
Squintz Palladoris's Avatar
5 gal of 110leaded mixed with 5 gal of 93unleaded killed my O2s almost immediately and had my motor running lean as hell. Unfortunately I could not get the densos local so I grabbed some bosch.
Guess I will run 100octane unleaded untill I hear the densos are workin well with the good stuff
Brad
Old Sep 16, 2004 | 12:40 AM
Solid346's Avatar
is there a way to delete the o2's or trick them as they are there. i am running on open headers with 2 bullet mufflers
Old Sep 16, 2004 | 04:52 AM
BTL FED's Avatar
Ya you can tune the car open loop, and get rid of the 02 sensors
