Misfire after injector install?
However, the car seems to be thinking it's misfiring, specifically on the #8 cylinder and occasionally on the #6 cylinder. There's no noticeable performance loss or stumbling around. However, it flashes the SES light only at cruising between 1500-2000 RPMs, and usually only in 4th gear. It never sets the light permanently, and usually a quick blip of the throttle kills the flashing.
Bill has been using the HPTuners scanner on my car, and that's how we know the PCM is seeing misfires in the 6/8 cylinders. At idle, the #8 cylinder is counting misfires like mad according to the scanner, but there's no SES and the car doesn't feel like it's missing.
I've checked the #8 plug wire, reseated the injector harness connector to the injector, and made sure the injector was seated in the intake.
On a side note, Bill cannot seem to get my trims zeroed for part-throttle. But my WOT trims go right to zero every time.
Anyone have any ideas or run into this before? Thanks.
perhaps an O-ring got cocked or lost? Also swap #8 injector
with #2 (or whatever) if the vac leak doesn't pan out and
see if the misfire moves. Always a chance that a used
injector (or any non-virgin-wrapped) inhaled a hairball.
Just in case, though. Can I clean the injectors myself? Or do I need to send them off somewhere?
if you have one cylinder that's out of bed with the rest
it's probably trying to tell you something. Going that
way might be better than just killing the code.
I have a 3000RPM stall, maybe a little heavier than yours
but not by much I think, and I see current misfire counts
of only 2-6 (but I also have stock F-body cam etc.). But
a loose plug wire gave me like 115.
