HELP!! Can't fill gas tank??
). I would not try sticking a something down to see if something is jamed up, you might push it down in the tank...or you might mistake something for the screen in the fill neck that some cars have (not sure if your car has it). Also try getting under the car and seeing if something is kinked.
And the manifold or EGR could have nothing to do with this problem.
I have heard of some pontiac's not being able to fill the tank if the SES light is on is there any truth to this?
Thanks for the quick replys.
Does your old tank still have the tank level sending unit? I'm trying to figure out what might have screwed up on the arm of mine before I take it all apart... EJ
