Do these Ford 42# injectors plug right in?
Old Sep 18, 2004 | 04:17 PM
ROCNDAV's Avatar
Default Do these Ford 42# injectors plug right in?
As asked, do these Ford 42# injectors plug right into our LS1 Harnesses without any modification? How about between Rails and intake? Has anyone used these? Do they run ok at our pressure? I'd like to use something like this with my 395.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Thanks,
David
Old Sep 19, 2004 | 01:00 PM
frcefed98's Avatar
Yep, had a set of 42.5s on my car before upgrading to mototron 60's.
They fit perfect, but you will have to get your PCM tuned for them, if you didn't already know and they run awesome at our FP levels, the effectively become 50lb injectors at 58psi, but if you have a ADJ FPR you can turn down the FP.
J
Old Sep 19, 2004 | 01:07 PM
horist's Avatar
yup work fine... that's what I'm running ... they run higher than 42.5 (as mentioned) at our pressure (58psi 4 bar, 3 bar is 43 psi which is what most rate injectors at ... so 36% more flow, so 136% 42.5 is 57.8 ... so at 4 bar the FMS 42.5s should flow about 57/58 lb/hr)
Old Sep 19, 2004 | 01:25 PM
ROCNDAV's Avatar
Thanks guys. I reckon these will work great with my 395?
David
Old Sep 21, 2004 | 01:02 PM
ChevyNo1's Avatar
I've got a set of 8 with less than 1K miles on them, flow-tested a week ago, all within 2% of spec. I'll ship them for $300 obo.
- Dug
Old Sep 22, 2004 | 06:49 AM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
thats's what i'm running on my 395. but unless you are running a big dry shot like i am you really dont need injectors that big. 36lb would be fine.
Old Sep 22, 2004 | 10:33 AM
ROCNDAV's Avatar
They seem to be priced so close that I was thinking on moving up to 42.5 pounders just incase I did something like that in the future. If I don't are 42.5 too big to "tune down"?
Thanks,
David
Old Sep 22, 2004 | 10:41 AM
antz01ta's Avatar
no mine tuned fine, they will work for you.
Old Sep 22, 2004 | 10:52 AM
ROCNDAV's Avatar
Thanks Antz, you been a big help along the way. I can only hope to have as good as times as yours when I finally get done with this thing (although thats a real good 60' time)
What exhaust are you running on that bad boy?
D
Old Sep 23, 2004 | 11:52 AM
ChevyNo1's Avatar
If you're still looking for 42 pounders . . . I'll even take $250 shipped. Gotta get rid of 'em!
- Dug
Old Sep 23, 2004 | 01:43 PM
antz01ta's Avatar
D
im running kooks stepped 1 7/8 - 2" - 3 1/2" collector with a 3 1/2" o.r. y pipe and into a 4" mufflex exhaust. i love the sound of it, its so deep and throaty, it never gets really loud but just sounds incredible.
Old Sep 23, 2004 | 07:12 PM
Mike @ New Era's Avatar
We have the Lucas/Delphi #42 injectors in stock and on sale right now at $299.95 , they are a direct fit , the Bosch injectors will work as well but are a bit more expensive because they are no longer maunfactured .
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
Old Nov 26, 2004 | 12:10 AM
obrien24's Avatar
Do the ford injectors plug right in to the harness?
Old Nov 26, 2004 | 10:02 AM
Yes , they will .
Mike
585-865-1832
Old Nov 26, 2004 | 04:23 PM
obrien24's Avatar
The 39# 03 cobra injectors that I just bought don't fit
Old Nov 26, 2004 | 08:24 PM
slow's Avatar
The Ford motorsports injectors will fit, the 99+ V6 and Cobra's got a new pencil style injectors and will NOT plug into the LS1 harness. For some reason the GT still used the old style connector.
Ryan
Old Nov 27, 2004 | 07:07 AM
obrien24's Avatar
well that sucks. oh well. hopefully I can sell them.
