am i crazy on can this work?
Old Sep 21, 2004 | 12:13 AM
2plus2's Avatar
Default am i crazy on can this work?
i want to ultimately use the fuel injection components from a 2003 6.0L truck to fuel inject my 1st gen small block(i hate carbs). i can install all sensors and hardware except for the crank angle sensor or the cam angle sensor(which ever the trucks use)
how can i install a crank angle sensor? (never came with stock)
how can i install a cam angle sensor? (also never came with stock)
has anybody done this before?
I very much appriciate any input on solving my problem. thank you
Old Sep 21, 2004 | 10:55 PM
SS2win's Avatar
the problem is easily solved by using a TBI or TPI from a 1990 or so model year since they are designed to run on first gen small blocks. OR drop in the whole 6.0...
Old Sep 22, 2004 | 03:11 PM
2plus2's Avatar
a TPI out of a 90' uses the 1st gen block?and 1st gen heads?
Old Sep 22, 2004 | 08:26 PM
SS2win's Avatar
manifold bolts right on. only mod you need to make is to the center 4 bolts holes. check the info on thirdgen.org. it is a very common swap
Old Sep 23, 2004 | 09:26 PM
2plus2's Avatar
thank you for the info
Old Sep 24, 2004 | 01:49 PM
92CamaroReallySlow's Avatar
What ever you do, dont go TBI! TPI is the way to go.
