Injector information needed
Old Sep 22, 2004 | 03:02 PM
gojo's Avatar
Default Injector information needed
Can someone tell me if these values are correct for 30lb SV0's on a C5?
Thanks.
Injector Rated Flow Rate 36
Fuel Rail Pressure 58
Injector Rated Fuel Pressure 29.5
Old Sep 22, 2004 | 07:04 PM
gojo's Avatar
Thanks.
I'm using the Excel calculator and don't know if 36 is right or what "Injector Rated Fuel Pressure 29.5" is.
Anybody?
Old Sep 22, 2004 | 07:18 PM
AnthonyR's Avatar
ford injectors are rated at 2.7 bar which is like 39.15 psi I believe.
Old Sep 23, 2004 | 07:17 PM
Mike @ New Era's Avatar
The flow rating they are rated at is 43.5 psi , just about 3 bar . Pretty much all injectors are rated at this psi level when flow checked .
Old Sep 23, 2004 | 08:57 PM
gojo's Avatar
Now I'm really confused. Can you put the values on each line for 30# SV0's?
Thanks
Old Sep 24, 2004 | 12:39 PM
PREDATOR-Z's Avatar
SVO 30" are 34.54 at 4 BAR (58psi) which is stock pump rating.
Old Sep 24, 2004 | 12:49 PM
gojo's Avatar
Thanks, those #'s get sensible results when entered into the Excel calculaor.
