do-it-yourself dual pump 2.0
Old Oct 6, 2004 | 11:27 AM
Tiago's Avatar
the block itself will accept brass fittings. I just think that a 1/2" fitting is gonna be too big.
Old Oct 6, 2004 | 11:34 AM
cablebandit's Avatar
the pep boys fuel injection hose starts swelling and seperating internally for me. I do not like it but could just be me
Old Oct 6, 2004 | 11:43 AM
MECHAM's Avatar
i got some GOODYEAR 300psi hose from my builder and it seems to be working fine. (so far )
Old Oct 6, 2004 | 11:53 AM
MIGHTYMOUSE's Avatar
mine is the RUS-650360
i stretched the 5/16 hose over a 3/8 barb because i couldnt find a 3/8 npt to 5/16 barb anywhere... no biggie
the outlet is 1/2 npt because that easily adapted to my -8 bulkhead fitting with a 1/2 npt male to -8 female without choking it down like the 3/8 would... and is easily upgraded if i ever need -10 line
Old Oct 7, 2004 | 10:45 AM
Tiago's Avatar
Hey David, do you have any kind of special wiring done to the pumps? or just split the stock power supply to both pumps?
Old Oct 7, 2004 | 11:52 AM
both pumps get power straight from the + post up front with a fuse.. back to one 30 amp relay that is switched on by the factory power wire for the pumps. they are gounded the same as stock
one pump is run by a short secton of the factory grey wire into the sending unit.. the second pump i drilled a small hole and put in a grommet around the + wire and sealed it up.
Old Oct 20, 2004 | 09:35 PM
nick y's Avatar
Originally Posted by BOOSTAT4500
Mightymouse- You are my hero man!! Your last posted answered my final 2 questions about this setup- wiring and line size/type. Thanks again for the info and pictures! Is it 5/16 all the way to the rail?
here too!
Old Oct 22, 2004 | 07:59 PM
KHShapiro's Avatar
After i saw this i talked with Several top fuel guys and they all saided the same thing that the y-block was the way to go as the T was causing the fuel to fight flow between the two pumps and the Y-block was going to create an even flow
Old Oct 22, 2004 | 10:19 PM
always somebody a copyin' my set up
...next thing they will be running 10 walbro 340 in-tanks.
Old Feb 17, 2005 | 10:54 PM
SINISTER's Avatar
hey guys for those of you that have done this
i have all my parts and my sending unitout
its a 99 so its plastic im gonna do the yblock set up and the twin pumps
did you guys scrap the bottom containter and let it all hang free??/
anyone have a pic of what its suppose to look like just right before you drop it into the tank???
Old Feb 18, 2005 | 09:56 AM
SINISTER's Avatar
anyone?/ buel;er bueler
Old Feb 18, 2005 | 10:55 AM
  #32
smokinHawk's Avatar
on my 99 twin pump setup i just cut bigger holes in the bottom plastic to allow more fuel to get in there faster,
id like to see if i can get three pumps in there, probably will have to severly modify the plastic bucket.
hey mighty moust, where did you get the replacement filter socks?
Old Feb 18, 2005 | 12:02 PM
  #33
Muffracing's Avatar
The "sock" is called a strainer. I don't know if the walbro uses the same strainer as a stock pump, but most Auto parts stores carry a few different ones.
Old Feb 18, 2005 | 12:53 PM
  #34
SINISTER's Avatar
cool thanks
Old Feb 18, 2005 | 04:54 PM
  #35
i went to pep boys and 'tried on' different ones
now i have 2 more new ones that came with the new pumps
