quick question about AN fuel line
Old Nov 15, 2004 | 12:14 AM
kossuth's Avatar
Default quick question about AN fuel line
I see alot of guys running AN lines on here for fuel lines, I was just curious as to just how reliable it is and what the operating pressure for it. I plan on running AN line from the fuel rail back about 1/2 of the way back to the tank on my S10 and using the factory lines from there being the stock lines are 3/8 inlet and 5/16 return. Gonna use compression fittings with AN male fittings on the end on the steel lines. I'm using 97-98 C5 fuel rail. I know this is kinda a conversion question but it is also a fueling question. Thanks for your input. I'm fairly certain it should be ok, just want a warm and fuzzy you know. Thanks again.
Old Nov 17, 2004 | 06:07 PM
MIGHTYMOUSE's Avatar
i believe all the normal fuel rated line that summit/jegs etc. carry is rated to 300psi.
