siphoning gas?
You can get a reverse inline pump and put hose out each side of it, just slide the hose down into the tank, power the pump and out comes the gas.
1) if the tank that you are siphoning is full enough, push the hose in all the way, seal the end with your thumb, and pull it out with a fast action keeping your thumb over the hole. then quickly shove the hose back in the tank while you take your thumb off the hose, covering it again before you pull it out again. it takes some practice, but if you get the timing right, and manage to keep the tank end of the hose covered in gas it will work. the same principle works with a glass of water or soda with a straw in it, push the straw all the way down, pull it up quickly with your thumb over the end, push it back down quickly with your thumb off, repeat and the fluid will travel straight up the straw. i've never heard of the 'shaker siphon' that that Tudds mentioned, but i'm almost sure it works the same way.
2) put your siphon hose in the tank, and then put another hose in the tank. then take a shop rag or whatever and seal up the filler neck and the hoses. then either blow REALLY hard into the non-siphon tube or simply use a compressor to blow air into the tank. the pressure created will force gas out the siphon tube. this works real well for emptying a tank since you can move the siphon hose around in the tank while air is being blown to try to get every last bit out.
Or, take the hose you're going to use, and fill it with gas (or water, if its not a lot it won't hurt). Just stick it in a bucket and make sure theres no air. Plug both ends with a finger and walk over to your car. Let go of one end, and keep the other end plugged up tight! Feed it into the tank, and very little fluid should get out. Now just make sure the end in your hand is lower than the tank, and let go. It shoud start running out.
Or, just buy a damn siphon pump. You squeeze the little pump until the line is full, then just let it run.
