my stage 3 fuel system
#63
Originally Posted by MIGHTYMOUSE
i think speed only sells their alternator booster thing.. find out if it is that or the msd voltage booster or the kb boost a pump. i dont want to increase the voltage to my whole car.
i dont know if i can fit a third walbro in there.. if i could it would be the 3-way connection fitting that wouldnt fit.
i dont think it would be too hard to make a braket or even a three way tee, ofcoarse things are easier to make when you have your own tig.
#69
Follow up on an old thread....
I found this link with the Bosch Motorsport 044 pump, which seems to confirm it can be used in-tank as well as the normal in-line external.
http://www.mantissaconsulting.com/et...uel_system.htm
