Carb Vs EFI discussion
That is all.
Show me a carburettor car that can make almost 300bhp per litre yet still be a daily driver...I know of a few turbocharged Subarus and Evos making around 600bhp on pump fuel, yet are driven daily.
Do you think fitting them with a carburettor will offer benefits ?? Not likely. Id say you would lose about 250-300bhp, and most of its driveabilty with carbs.
There are Supras and LS1's making around 1000bhp, again, still daily driveable. Do any of them have carbs ??? No.
trying to compare a stock efi system to an all out race carb setup, on maximum power only is stupid.
Compare like for like, if thats possible. Efi wins hands down.
with a carb, there are always compromises. with efi, there need be no compromises as far as obtaining optimum AFR are concerned.
No doubt some carb manufacturers and sellers will try and convince you otherwise, but fuel injection is simply better.
Given turbocharged efi production cars have been around, certainly here in the UK from the mid 80's, I dont think that it is limited to race only cars.
In fact, we havent had a production car here with a carburettor since about 1992, which is all good.
Carbs are simple, but if you have ever tuned a car with a good user friendly efi system, you will see how easy they are to work with.
But what they are to tune, is hassle, full of compromises.
you've never tuned one
you can't even spell carburetor
That is all.
But... I do know I prefer sitting in my car on a hot summer day w/the A/C blasting looking at my latest logs and making changes... then 30 seconds to reflash
Seems alot of it comes down to what you know... I know EFI systems but not Carb cars... Carb supporters generally seem to know Carbs very well but don't know EFI very well...
To me it just makes alot more sense changing numerical values in tables in the PCM... ideally a pretty exact science (unfortaunetly not the way it really works)
Perhaps there is more than one spelling then....
May as well ask is better a manual trans or a auto, chevy or ford.
Some guys can do well with carbs and hate EFI.
Some guys can do great with EFI and hate carbs.
Some guys can do well with both.
Substitute manual/auto or chevy/ford for EFI/carb in the above 3 sentences and you have 3 true statements
There is one situation in which port injection does have a distinct advantage over carburetion, but nobody here has even touched on it.
This tells me that those involved only have a partial grasp on either concept.
What I said about carburetion is true.
If some EFI lovers get their feelings hurt when carburetion is brought up, then that's just a character flaw.
Im still waiting for any examples of 300bhp per litre carburettor powered engines ?? Or perhaps 250bhp/l or even 200bhp/l which still return good fuel economy, and total driveability on the road..
Are there any ???
If you don't want to give away some secret to tuning a carburetor I can understand but, I doubt there are TOO many secrets left to them after all these years.
BTW, my feeling aren't hurt either. I've driven both and maybe because I was brought up with computers/electronics and things like that I'm more comfortable around the EFI stuff. I don't think anyone here is getting their feelings hurt talking about carburetors it's HOW some people are saying something and not presenting reasons for it that is getting people a little "upset".
EFI does rule for big torque down low.
Its like asking: Is Ketchup is better then Mustard?
One is not better then the other. They are just different.
Also, given the same average outside air temp, a carbureted system will always have a much cooler intake charge feeding into the head port. This temperature difference increases the density of the charge as would be measured on the top side of the intake valve. This increase, along with the increased density due to pulse tuning of a more massive charge adds up to a greater pressure differential when the intake valve opens... allowing the same head port & valve to flow a greater mass in the same given time duration.
Besides the obvious weight, reliability, and simplicity advantage a carburetor offers, you see there are times when they can produce more power as well.
During low-load high-vacuum driving, the fuel from a carburetor will be flash vaporized by the low pressure existing in the intake manifold, so there is really no problem with atomization or significant distribution problems in most manifolds. They can run very cleanly and return great mpg numbers when set up properly.
This allows someone with port injection to use much larger intake ports without killing too much low-RPM power. This shows it's advantage at higher RPM once past the tuned RPM range of the intake runner itself. In other words you can get away with much slower velocity in the intake manifold and head port and reduce restriction at high RPM.
A carburetor requires you to maintain good velocity throughout the intake manifold and head port so that fuel doesn't drop out of suspension at lower engine speeds.
a sheetmetal intake and 240cc intake port heads is not a very streetable combination with carburetion unless you swap to a IR multiple carb set-up,
but would have no problem being streetable with port injection.
In application there is also a big difference between a wet-flow induction and dry flow.
its the carb that is more likely to "spray droplets" of fuel.
That is another reason why efi cars produce much cleaner emissions.
