how much fuel line to order??
Old Jan 18, 2005 | 10:09 AM
SINISTER's Avatar
Default how much fuel line to order??
im going from tank up to rails with -8 and with a speed inc fuel filter
and - 6 on the return with speed inc fuel rails
i ave the same y-block set up as mighty mouse
i just need an idea on how much feet of line to order ? and one have a clue on how much -8 or -6?
thanks!
Old Jan 18, 2005 | 10:20 AM
xssive's Avatar
Well 15 feet goes from the tank to the rails with about 2-3 feet left over for mistakes. The return will depend on if you are running all the way to the tank, or using the stock feed as the return.
Old Jan 18, 2005 | 05:16 PM
Beast96Z's Avatar
I ordered 20ft. for both just in case.
Old Jan 19, 2005 | 07:10 AM
SINISTER's Avatar
sounds like a plan
thanks guys
any sponsors have good prices on fuel lines and fitting, if not ill go with summit!
Old Jan 19, 2005 | 05:14 PM
Beast96Z's Avatar
I used all aeroquip parts from summit. They had the best prices I could find.
Old Jan 30, 2005 | 09:23 PM
SINISTER's Avatar
whats the easyest way to cut this stuff?
Old Jan 30, 2005 | 09:31 PM
MIGHTYMOUSE's Avatar
i think i got 20 also, have some left over.. im sure it will come in handy one day.
the best way to cut it is wrap over where you want it cut with duct tape and then cut with a dremel and a cutoff bit. if you cant do that use a hacksaw.. have to be careful to keep the braids tight or it will never fit.
Old Jan 30, 2005 | 09:38 PM
SINISTER's Avatar
thanks i just ready to order everything im just looking for this last fitting
that goes from my -8 line into my -6 regulator
i need a -8 hose end with a -6 male
Old Jan 30, 2005 | 09:41 PM
if you have the speed (cas) regulator.. apparently now they carry both the -6 and -8 fittings for the regulator, you get that and you wont have to use an adaptor.
if you are using a section of -8 for the return line i would def. get 20'
Old Jan 30, 2005 | 09:45 PM
SINISTER's Avatar
i got 20 in my shopping cart at summit
thanks dave once again you help me out
does speed have these fittings for the reg?
Old Jan 31, 2005 | 06:45 PM
NA$TY-TA's Avatar
On that part you PMed me about its a 8an to -6an reducer and i ordered it from summit and i also ordered a -6an O-ringed plug.... call the customer service guy and they can help u out.
Kyle
