fuel system advice for NA setup...
Old Feb 6, 2005 | 11:47 AM
Hardtop00SS's Avatar
Default fuel system advice for NA setup...
I will be adding stage 3 LS1 heads milled .10 with a TSP 233/239 cam with stock block and I have a stock fuel system right now. I never thought about changing it until recently, is it necessary? What are the stock system limitations? What would be the best combo for my system? I don't want an in-line pump, I'd rather do an in-tank setup. I'm assuming if I change the pump, I will have to change the injectors, correct?
Thanks
Old Feb 6, 2005 | 03:04 PM
jrp's Avatar
jrp
SN95 Director
i've got SV0 30#'ers and the PnP Racetronix kit. i should be in the 450-470rwph range. since you have an 00 definately get the injectors, the 26#'ers aint gonna cut it.
Old Feb 6, 2005 | 04:16 PM
Thanks for the reply, I have a buddy that wants to sell me his injectors, I think they are either 30# or 36#, I can't remember, do you think the SVO 30#er's should be ok? Where can I buy the racetronix kit?
Old Feb 6, 2005 | 05:58 PM
jrp's Avatar
jrp
SN95 Director
30#'ers are 34#'s with the LS1's 4bar FP. you can get the racetronix kit from TR.
Old Feb 6, 2005 | 10:16 PM
I just talked to my buddy and he has 38#er's off his SC Hawk, those should work for me right? Also, should I look into new fuel rails? I was looking into Speed Inc.'s system with the external regulator, would they aid the rest of the fuel system? Thanks for the help JRP...
Old Feb 7, 2005 | 04:31 PM
72ChevelleConv.LS1's Avatar
to find out what injectors you should need. Say you are hoping for 600 hp. Horsepower X BSFC (constant of .5)= fuel required. IE 600 hp X .5 =300 lbs fuel per hr. now you need to figure out what lb injectors to use. Lbs fuel hr / 8 injectors.=37.5 @100% duty cycle. you want to use maximum of 80% duty so you need to take the 100% rating of 37.5 and / by .8 or 80% and find that you should use 46.87 lbs/hr. injectors. you can use this to apply to any hp rating.
Old Feb 7, 2005 | 05:16 PM
sweet, thanks 72ChevelleConv.LS1, well I used the formula and it's saying that I need 42# injectors. Does this sound right? That seems a little much for a H/C car?? Someone check my math, 550(FWHP)X.5=275, 275/8=34.375, 34.375/.8=42.96. did I do it right?
Thanks
Old Feb 11, 2005 | 05:42 AM
Looks correct to me. This way is best for your app. the closer to the 100% duty cycle you are the more close you will come to having a fuel issue with supply. your welcome!
Old Feb 11, 2005 | 08:04 AM
V6 Bird's Avatar
Under NA use though I dont believe in your calculations. Sorry. FI then yes.
Mike
