methanol
Old Feb 8, 2005 | 02:29 AM
everx's Avatar
Default methanol
im some what new to the whole meth. thing. but with methanol injectors can u set it up to run of pump gas then switch over to meth? or do u use pump gas for the meth injectors? also if u do upgrade to meth injectors what else is needed to make it work suffecently? sorry for the stupid questions but again im new to the whole methanol thing. any information would be appreciated
Old Feb 8, 2005 | 08:08 AM
white2001s10's Avatar
An injector that's good for methanol will have no problem with gasoline, but the tune will have to be vastly different.
Methanol is best used as an on-demand fuel for WOT, and is not good to drive around on.
What exactly is your plan? maybe I can give more useful advice.
Old Feb 8, 2005 | 09:10 AM
bryson's Avatar
I have a question also -- where can you buy injectors and a pump that can handle methanol? I have access to a TIG welder so I will probably make an aluminum pump, and weld bosses into my manifold, but I don't know what injectors to use. I need at least 160lb injectors, along with a pump that can sustain 4 of them. Any info would be great! Thanks!
--Bryson
Old Feb 8, 2005 | 09:36 AM
Aeromotive makes a pump model that will work with methanol and is rebuildable. They are over in Kansas.
http://www.aeromotiveinc.com/
MSD and a couple other companies make injectors for methanol and should have the size you need.
http://www.msddis.com/fuel_4.htm
http://www.injector.com/fuelinjectors.php
Old Feb 9, 2005 | 02:35 AM
everx's Avatar
i want to get the sts kit and run 7 psi 1 way is to get an inter cooler. the other way is to go meth. i want it to be a street machine but i will take it to the track too. but mostly street. so what would u advise doing?
Old Feb 9, 2005 | 08:44 AM
7psi is pretty low so you don't HAVE to go either way but,
if you want less hassle go with the IC,
if you're going for maximum power then go with either methanol or both.
If maximum power isn't so important and you really don't want the IC, then
water injection will be much less of a hassle.
Old Feb 9, 2005 | 08:46 AM
bryson's Avatar
For just alcohol injection, it's easy. If I were you, I think I would run both. I made my existing alcohol injection system for about $150. There's a good site that kind of gives a basis for an alky system. You don't have to follow it exactly (I didn't), but you certainly can if you want to. http://members.***.net/stevemonroe/AlcoholInjMod.html <-- I've done this on my car and on a buddy's RX7. Good luck!
--Bryson
