Going bigger in the future, plan ahead now?
Old Feb 12, 2005 | 02:14 PM
99BackNBlackZ28's Avatar
Default Going bigger in the future, plan ahead now?
I've got a 02 WS6 right now (see sig below) and in the next month or so I'm planning on having a custom ground Futral cam put in as well as a 100 shot (dry). Im upgrading to a Walbro255, & I was thinking about some SVO 30#........ but at the same time, the next upgrade will be a forged motor (most likely 370 or 406). Should I go with a bigger injector now? Perhaps a Racetronix 37#? What's the best injector for the $$$? Are injectors easy to tune via HPTuners?
Old Feb 12, 2005 | 10:12 PM
jerflash's Avatar
i think that 30# svo will be fine for you future plans from what i read
they are like 36# on our pressure
i have them in my car right now
Old Feb 13, 2005 | 09:48 AM
Badzracing's Avatar
If you're like everyone else here, you'll end up wanting more than you "plan" on right now. You might want to consider a wet kit. With the wet kit, the 30's should be fine even if you decide to up the jets to 150hp or so. Tuning for injectors is very easy with hptuners.
Old Feb 13, 2005 | 05:44 PM
HAMRHEAD's Avatar
Go with a wet kit and get the SVO 30# injectors. Now you'll be set for your future plans.
Old Feb 13, 2005 | 06:43 PM
Nah, staying with dry. Thanks though.
Old Feb 14, 2005 | 04:35 PM
I decided on the Racetronix pump & 37# injectors. Now only if someone over there would answer my e-mail about paying $30 to ship a pump & injectors, I'd be set!
