Racetronix pump installed
Old Feb 19, 2005 | 10:30 PM
DrkPhx's Avatar
Thumbs up Racetronix pump installed
Since I already had the rear out I bit the bullet and decided to drop the tank to install the Racetronix plug n play pump. The installation of the pump was the easy part, but getting the tank in and out was a ****. Hooked everything up and the fuel gushes out now compared to the stock pump.
Old Feb 20, 2005 | 06:24 PM
jrp's Avatar
jrp
SN95 Director
i did my install a few weeks ago and getting the tank in and out was a ******* bitch. @ the metal fuel neck . did you drop your rear end?
sickss228's Avatar
I also installed the racetronix pump alittle bit of a pain in the *** but well worth it. Theres no drop in fuel pressure now, definatley a good investment
Old Feb 20, 2005 | 09:30 PM
DrkPhx's Avatar
Yes. I had the rear out to install a 12 bolt. I could only imagine how hard it would be (if not impossible) to do it with the rear end in place.
Old Feb 21, 2005 | 04:00 PM
sickss228's Avatar
I had the rear in place when I did mine just unbolt the shocks at the rear and let it drop all the way down. A little tight but it'll work
Old Feb 21, 2005 | 04:06 PM
jrp's Avatar
jrp
SN95 Director
you also have the plastic tank . 98 tanks are metal.
Old Feb 28, 2005 | 11:52 PM
waterbug1999's Avatar
Yea, I helped a buddy out one time and it was kind of a PITA..
But, a learning experience for when i have to put mine in.
Old Mar 2, 2005 | 07:17 AM
gogogadgetcar's Avatar
i did mine when i put in my 9" not hard at all
probably quicker to just pull the rear off than fight with it in place
Old Mar 9, 2005 | 11:15 AM
Y2K2LS1's Avatar
lol
Was it a PITA because you still had gas in the tank maybe? I'd drive the car untill its almost empty before I'd bother to drop the thing! 1 gallon = 7lbs or something like that.
Old Mar 9, 2005 | 05:21 PM
No, the tank was almost empty (1/2 gal.).. Just getting the fuel lines back in the original position with out a kink was the problem. All good, just undid the hose at the fuel filter and after that, the fuel line slid right up with out a kink.. A learning experince.
Old Mar 9, 2005 | 07:37 PM
jerflash's Avatar
i just ordered the racetronix pump for my 2002 earlier this week hope to get it soon because i will ahve the rear out for a 12 bolt swap
all i know is that the 98 pump cant be nearly as bad as doing the pump on my 89
i took the panhard bar off and unbolted the shocks and moved the exhaust and it was still a bitch
Old Jul 17, 2005 | 01:44 PM
Somebody09's Avatar
Did you guys clean out your tanks when you did the swap, as Racetronix recommends? If so, how did you clean it? Soap and water?
Thanks,
somebody
