'98 Racetronix Fuel pump owners:
Old May 1, 2005 | 12:42 PM
WMSuperSport's Avatar
Default '98 Racetronix Fuel pump owners:
My instructions didn't mention anything about all the extra wiring harness, relays, etc. The instructions only included the main pump install and pump power wiring install. Do I even need the extra harnesses, connections, and relays, etc?
Thanks,
Wes
Old May 1, 2005 | 01:41 PM
kp's Avatar
kp
Probably dont NEED the extra harness but it will get more voltage to the pump instead of using of using the skinny little stock wire. I didnt get any instructions for the wiring either, I ran the big wire to the main fusebox on the pass side, they recommend running it to the alternator, and just plugged the harness in. I didnt use the extra ground wire they suppliedm the car already has a 1 or 2 gauge wire from the battery to the body.
Old May 2, 2005 | 12:05 AM
SapphireHawk's Avatar
How did you run the wire to the engine bay? Did you run it along the fuel lne or through the car?? I was thinking of coming into the car running under the carpet and then through the firewall. I am not crazy about extra wires running underneath the car.
Old May 2, 2005 | 12:08 AM
DrkPhx's Avatar
Run it alongside the fuel line and secure with the enclosed zipties. I connected the positive to the fuse box and did use the ground strap also.
Old May 2, 2005 | 07:14 PM
Default wiring harness
So would I just have a less pressure running the stock wiring?
How much RWHP will the stock fuel pump wiring hold to? I know this is a vague question but any info would be great. I don't want to run the extra wire if I don't need to.
Thanks,
Wes
Old May 3, 2005 | 01:02 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Install the harness. It takes all of 20-30 minutes to do and will guarantee maximum pump performance.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old May 3, 2005 | 01:03 AM
Racetronix's Avatar
LS1TECH Sponsor
Fuse box?
__________________
>WEB SITE<
