Should I sell my Imedance converter and run 75lb High imp injectors??
I am planning on running 83 lb injectors with my Impedance converter to support 800-900 RWHP with the twin turbo 347 I have. Should I sell it and just run the 75 lb RC Engineering injectors? I want simplicity, but I also want the best idle and part throttle driveabilty. This is for a street car. I have a stock pcm and am a little up in the air on what I should do.
Does anyone have first hand pro's and con's type of experience they could tell me??
Anyone??
I guess what I would like to know is how many horespower can 75 lb injectors handle at 45 psi. I run an A1000 fuel pump and do not want to have to crank the fuel pressure to high.
If the 75 lb injectors would work good and have no idle richness problems or anything, I will just sell my converter and buy some 75 lb high imp injectors.
Anyone??
Anyone??
