104+ octane booster causes misfires/fouls plugs
I'm currently in Kansas. The best pump gas they have here is 91 octane. I've put like 3 bottles of 104+ in my tank with fill ups. I did not know if 91 octane would cause detonation on the 100 shot. Better to be safe right. Wrong I had 6000 miles on those ngk tr6 plugs. Fouled plugs and misfires were the result. No more 104+ for me. Any one else had the same problem?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Misfires with octane booster can be a pretty common problem. The plugs get this redish brown coating on them and they will start to misfire. It usually takes alot more than a few tanks of gas with it though, maybe since the TR-6s are colder it happens quicker. I would invest in a way to pull timing instead of buying octane booster. Your not running the HPP3 tune with nitrous are you? If you really want to continue to run an octane booster give Torco a try. It seems to be the only one out there that really works like it should.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
store bought octane boosters are a joke. if it says itll raise the octane by 4 points, it means itll turn your pump 91 into 91.4, so it does nothing really. i just posted to someone looking for at least 104 octane...you can add some paint chemicals to pump gas to make it race gas. like 30% acteone and pump 92 or 93 will give you 108. theres also some chemicals called toulene and xylene that in 30% mix will raise you to pump 108ish. this is real octance boost, not pu$$y boost. do a search on it, you can also go to some turbo buick site and do a search for octane booster or the chemicals i listed abve. i knwo there are a couple other chem too...
products clearly. I read the front and back of containers to make sure and
I've used only once.
