when do I upgrade injectors/fuel pump?
I have a 3500 stall Automatic 98 camaro
I believe it has stock 28lb injectors.
engine mods are:
347 shortblock
stage 2.5 5.3 heads
MS3 cam
Z06 MAF
Lid
LS6 intake
Pacesetter Long Tubes
Duel race mufflers
!Cats
!EGR
!AIR
!Thermostat
I have not recieved my engine, heads, or cam yet I'm just wondering should I upgrade the Fuel pump and/or Injectors at this point.
Old setup:
stock 346 shortblock
stock heads
TSP 231 237 cam
Z06 MAF
Lid
LS6 intake
Duel race mufflers
!Cats
!EGR
!AIR
!Thermostat
For the pump , get a mechanical gauge and hook it up to your hood so you can see it while driving. At idle it should be 58-60 and at WOT you probably don't want it to go below 54-55. If it does, time to upgrade.
FWIW on your setup I believe you may max out the injectors; what year is your car?
See my sig below; I just picked up 42lb injectors and after getting them in I plan on doing the gauge as described above.
Can anyone confirm this? I was under the impression that 98-99 had 28lbs stock and the 00-02 had 26lbs.... Does anyone have some hard data, because now I'm confused.
