Cutting for fuel pump
Old Jul 18, 2005 | 04:09 PM
FormulaFire's Avatar
Default Cutting for fuel pump
What are the measurements of EXACTLY where to cut the sheetmetal to install a new fuel pump? I plan on doing it tom and don't what to cut up everything.
Thanks,
Justin
Old Jul 18, 2005 | 04:41 PM
CrawlinWS6's Avatar
Import Patrol
ON my 2002 T/A when you pull back the carpeting you will find 3 lines in the metal. I cut from line to line from the bottom to top about 8inchesl. Worked like a charm
Old Jul 18, 2005 | 09:18 PM
from which line to which line? Is the pump kind of in the middle?
Old Jul 18, 2005 | 09:36 PM
Mazzenger's Avatar
depends on what year your car is. 98's are in the middle.
Old Jul 18, 2005 | 09:47 PM
what about a 99 TA ??
Old Jul 19, 2005 | 06:06 AM
Blown408's Avatar
Dropping the tank really is not that hard. There are just 2 bolts holding it in place.
I almost decided to cut the hole myself, but changed my mind at the last minute.
Just be careful that you don't cut through any fuel lines
Old Jul 19, 2005 | 08:53 AM
CrawlinWS6's Avatar
Import Patrol
I used an angle grinder for ine with a cut off wheel, If you use something like that or a rotozip or dremel, I had started out with putting electrical tape down so I had the edge of the tape to guide myself so the cut would be straight, then went all the way around with just a small cut into the metal then I cut all the way through, sections at a time.
Old Jul 19, 2005 | 09:08 AM
dropping the tank would mean cutting the exhaust, and welding it back..HMMM.. that's a little too much trouble for me.. I will try cutting it sections at a time. Thanks guys..
