whats the best on line fuel pump
Originally Posted by Racetronix
The HP support depends on whether your motor is NA or FI and whether or not it has a FMFPR (97/98).
Typical numbers based on adequate fuel volume assuming stable regulation (BSFC dependant):
600RWHP NA w/o booster (13.5V)
700RWHP NA w/booster (17V)
550RWHP FI w/o booster (13.5V)
650RWHP FI w/booster (17V)
Some customers have exceeded these numbers and some have fallen shy depending on their application. A 97/98 FMFPR system is highly recommended for all applications.
By the way, just to add, I put 572 rwhp through a turbo 400 w/non locking converter 3" steel nitrous ready driveshaft and a 12-bolt on a 100 shot with my stock pump. Tried the 150's and she went too lean and I let out, and she put 598 rwhp just before I let off. So I should hope that the racetronix i've put in there now would be good to more than 600 rwhp w/o the boost a pump if my stocker was holding just fine @ 572 rwhp! Had no inline, no nothing, just the stock pump.
LS1TECH Sponsor
Originally Posted by Loudmouth LS1
What is a FMFPR?
At high HP levels pressure drop becomes an issue that is why a front-mount fuel pressure regulator is required to stabilize rail pressure.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
The Racetronix pump will produce more volume than the factory pump.
LS1TECH Sponsor
Originally Posted by ls1290
What is the negitive aspect of doing this? I have heard that running two in series is better than two in parallel.
Keith
Keith
Series will provide higher pressure capability while maintaining volume.
Parallel will provide much more volume but pressure is more limited.
For F99+ cars series is not recommended while maintaining the bucket's functionality.
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Originally Posted by monsterchevylizzard
how does the walbro wire in if the stock intake pump has 3 wires ? what is the 3rd wire for ?
Sender has two violet wires.
__________________
>WEB SITE<
>WEB SITE<
