Injector Rated Fuel Pressure
Old Sep 8, 2005 | 04:50 PM
Kaneman's Avatar
Default Injector Rated Fuel Pressure
I have Siemens 57lb/hr injectors running dual Walbros Aeromotive FPR what would my Injector Rated Fuel Pressure be?
Kane
Old Sep 8, 2005 | 06:04 PM
Kaneman's Avatar
My fuel pressure is at 58psi..
Kane
Old Sep 12, 2005 | 11:28 AM
Kaneman's Avatar
Does anyone know how to determine what your Injector Rated Fuel Pressure is? I am trying to use the injector spread sheet.
Kane
Old Sep 12, 2005 | 12:58 PM
SMOKINV8's Avatar
Injector Rated Fuel Pressure is the fuel pressure which the injector flows 57# (in your case). So in other words, you need to contact Siemens and find out what pressure they flow their injectors at when they test them.
FWIW, its likely going to be 43.5psi, but you still should call Siemens.
Old Sep 12, 2005 | 02:18 PM
jimmyblue's Avatar
Moderator
See if yours are listed here, bearing in mind this is
just Somebody Else's Data:
http://users.erols.com/srweiss/tableifc.htm#LUCAS
Old Sep 12, 2005 | 03:32 PM
stevieturbo's Avatar
The industry standard for rating injectors is 43psi. So usually any advertised flow rate will be based on 43psi.
Old Sep 12, 2005 | 10:43 PM
jimmyblue's Avatar
Moderator
You would do well not to make any such assumption,
however. There are enough who don't adhere.
