30lbs on a 408 ok??
You want my list of REBUY's 3 cams
2 fast intake's 78mm now a 90mm
3 TB's ported stock then ported BBK now a NW90mm
2 sets of heads $2400 set of A/S 5.3's that will be sold to pay for the AFR225's
3 set's Injector's ????
3 exhaust's
1 set of mac's then switched to Kook's
2 lids 75mm now 85mm
2 mafs
I know there is more but i am going into deep depression and debt
to find the fuel requirements take your horsepower and muliply it by a BSFC(brake specific fuel comsumption) ie 550X.5(for NA streetcar)=275lbhr of fuel divide by # of injectors ie 8 so 275/8=34.375lb/hr. now explain how a 30# injectors will product that value without pushing it too much?very easy to solve.math is your friend when it comes to motors
SVO 30lb injectors are rated @ 40 psi, at 58 psi they flow 36.12 lbs
Thanks Shawn The Best V8 Stories One Small Block at Time
Thanks ShawnIf you were to use the SVO 42s you would have 48.5lb/hr @ 58 psi rail pressure. Plugging 48.5 lb/hr into the equation I get 81.57% idc. Just over the accepted 80%, but not too bad. Keep in mind, I used a "conservative .50 BSFC. The more efficient the engine is, the lower this # becomes and the less fuel required to make the same hp.
The equation I used for these calcs is:
(BHP)(BSFC)/(# of cylinders)(IDC) = lb/hr required
BTW will my stock pump be enough till the winter?? 4bar=58psi is standard GM fuel pressure
so 40#@3bar=48.5#@4bar (look in http://redhardsupra.blogspot.com/200...le-tuning.html for the full table)
Now here's my next ?? Will i be able to get my car tuned with the stock fuel pump?? then over the winter i will get a racetronix kit. Will my stock pump make enough?? BTW pump has 50k on it.
Matt
OK who has the best prices for a in the tank kit for a 98. I would assume an in the tank 255 would be enough??
