Any Kenne Bell boost-a-pump users?
Thanks!
Trying to decide to go with the BAP with my Welbro 255 or a complete fuel setup. Tell me your thoughts!!
Greg
2002 Z28 A4 (4L80E) 408, AFR 225, Turbo cam, TTI Street kit with T76, 12 bolt, BMR, etc.
Thanks!
Greg
Thanks!
Greg
fuel pressure is at 58-60 psi at wot it drops to 55. my car is tunned very rich.
hope this helps.
I switched to a dual in tank 255 setup and now the fuel pressure never moves with the injectors at 99% now at 600rwhp. Still on stock fuel lines.
But I would wire it so only one pump runs full time and the other is kicked on with a hobbs switch or something if you do a lot of street driving. The pumps really seem to work hard when they are both running.
Plus the KB has a remote **** you can put in the car to adjust the voltage boost so you can fine tune quick if you have a WB in the car.
Thanks!
Greg
