Ls1 Fuel pressure Problem.
Old Nov 16, 2005 | 11:33 PM
Hagar's Avatar
Default Ls1 Fuel pressure Problem.
I am putting an Ls1 in a 300zx. I have set the car up to run on two stock 300zx fuel pumps, (the 300zx motor needed 40# of fuel pressure). The ls1 from what I have read needs to operate at 57 psi of fuel pressure with the stock injectors. The problem I have is that my stock 300zx fuel pumps don’t like that high fuel pressure and screaming at me for it. My question then is, if I go to a bigger injector how do I know what to set my fuel regulator at? Is there a formula for this? My goal would be to get a bigger injector and be able to run a lower fuel pressure. Am I asking for to much?
Old Nov 17, 2005 | 01:40 PM
Nasty N8's Avatar
You can use a different injector but you would need to tune the computer for it. Why not add a LS1 style pump tot he tank and get the extra pressure?
Nate
