Injector Question
Old Nov 20, 2005 | 10:49 AM
Ta9864dodge's Avatar
Default Injector Question
Hi, new guy here I was wondering what replacement injector I can use on my 98 WS6 to replace the stock 28.8's? I am looking for something like a 30 but I dont know if any of the aftermarket injectors fit the stock injector harness?
Any help would be greatly appreciated, thank you!
Old Nov 20, 2005 | 07:26 PM
Can someone please lead me in the right direction with this, because this car has been apart for 3 years now. This is my last piece before driving it. The stock injectors varnished up and 4 of them aren't spitting fuel. So I would like to know my options on replacing them.
Old Nov 20, 2005 | 07:39 PM
bshell's Avatar
Read further down a page or two to see some of the similar "what injectors do I need" questions. It would also help to know what kind of mods you have now and what your goals are for the future. One thing to note though, the SVO 30# injectors (I assume that's what you were talking about) are significantly bigger than the stock 28.8# injectors because they are rated at 43.5psi. At 58psi (stock ls1) they are closer to 34.6#, or almost 17% bigger than stock. Hope this helps.
Old Nov 20, 2005 | 10:30 PM
Okay, well my mods are the ls6 set up, ported heads, cam, intake with long tubes basically. I would still be able to use the stock injectors if they werent varnished up. The cost of them though made me think that maybe aftermarket was a better way to go unless there is a good source for them out there.
Old Nov 20, 2005 | 11:33 PM
slow's Avatar
some sponsors have takeoff 2002 28.x injectors for $100, might want to look for those, vs paying close to that for a single injector from GM.
Ryan
