where to get an adapter from fuel rail feed fitting to -8AN
Old Dec 23, 2005 | 12:08 AM
TT_Vert's Avatar
Default where to get an adapter from fuel rail feed fitting to -8AN
basiccally, i want to get an adapter to get the quick disconnect fitting to a -8AN line. Kinda like this for a ford but for an LS1:
Dave
Old Dec 23, 2005 | 10:25 PM
oange ss's Avatar
http://www.thunderracing.com/catalog...&vid=4&pcid=10
Old Dec 23, 2005 | 11:07 PM
TT_Vert's Avatar
i looked at all those part #s on summit and not one will give me an AN fitting off the LS1 rail utilizing the quick disconnect function
dave
Old Dec 23, 2005 | 11:18 PM
Dixit's Avatar
Only place to get a fitting for the LS1 fuel rail is from Nitro Dave at NitrousOutlet.com
But his fitting is a -6an. He tried to get an 8an to fit on there, but no go, only -6an.
Dixit
Old Dec 24, 2005 | 12:21 AM
TT_Vert's Avatar
will a 6AN from a fuel rail to line be adequate? It'll be a good 2' span. The line is only 3/8" anyway
Dave
Old Dec 24, 2005 | 08:21 AM
xssive's Avatar
-6an is 6/16 or 3/8" line anyways. Its more than adequate
Old Dec 24, 2005 | 09:11 AM
99LS1_TA's Avatar
Summit has the adapters for a 6an line, Russells part # 640850
Old Dec 24, 2005 | 10:26 AM
Dixit's Avatar
This is the female side of the quick disconnect. I assume he wants the male side. That fitting only Nitro Dave sells.
Old Dec 24, 2005 | 11:03 AM
TT_Vert's Avatar
actually I think that is the side I need, it will slip onto the fuel rale male.
dave
Old Dec 28, 2005 | 10:28 AM
jtmiller92's Avatar
Thanks for the part #'s, just what I needed.......jt
Old Dec 28, 2005 | 11:13 AM
99LS1_TA's Avatar
JTmiller looks familiar, I believe you bought your LS1 engine from me. This is Lynn. How's your conversion coming along?
Old Dec 28, 2005 | 11:50 AM
jtmiller92's Avatar
Slowly but surely. lol Hope to have it all running sometime in late january. That gives me a few months to work out any bugs before Spring. Couldnt be happier with the engine, it was extremely clean inside and out. Ended up putting a TR224 cam in it while it was out of the car......jt
Old Dec 28, 2005 | 02:15 PM
Nasty N8's Avatar
We will have these fittings on all our fuel rail kits very soon.
Nate
Old Jan 3, 2006 | 12:41 AM
TT_Vert's Avatar
what do you have for me in the way of fuel rails? I pickd up a 2 pc front cover from you adn it worked well, maybe I can give you some more business
Dave
Old Jan 3, 2006 | 08:42 AM
Dixit's Avatar
Nasty has some "nasty" fuel rails. (in a good way). Lovely. Get those!!!
Old Jan 3, 2006 | 10:37 AM
TT_Vert's Avatar
the only thing i dont like is they are the exact same design as speed incs but more expensive and the rail size is only 3/8" whereas some are larger.
dave
Old Jan 3, 2006 | 11:25 AM
Dixit's Avatar
Do you need larger than 3/8" NPT? That supports well over 1000whp. I like Nastys because the bracket stuff is connected and welded to the rail where the others you have to put them together and I dont like the way they look at it.
Dixit
Old Jan 3, 2006 | 11:30 AM
TT_Vert's Avatar
my only concern is that if the rail is only 3/8" (6AN) why bother w/ any feed larger then 6AN?
Dave
Old Jan 3, 2006 | 11:40 AM
Dixit's Avatar
Maybe im confused are you mis understood me. The fitting is is 3/8NPT. But the opening is almost 5/8" or so to hold the fuel. You can definetely get a 3/8NPT to -8an fitting.
Dixit
Old Jan 3, 2006 | 11:45 AM
TT_Vert's Avatar
i know you can, get adapters. Im wondering if the fact the fitting is 3/8" NPT yet 5/8" ID in the rail restricts fuel flow. After all, you are only going to flow as much fuel as the smallest orfice will support. If i have -8 lines and a 3/8 to 8AN adapter, my bottleneck is the 3/8 (approx 6AN).
Dave
