Where to get Injectors flow tested?
I searched and cant find where people recommend to get injectors flow tested?
I dont need them cleaned, they are brand new, just would like to get them blueprinted and tested with a flowchart so I can see before hand what the numbers are.
I know RCengineering does it, but I heard they are a bit expensive and there are others that do it for far cheaper.
Dixit
Dixit
I found a few more places last night after extensive searching on google.
These guys do it for $5 on just blueprinting.
http://www.cruzinperformance.com/fuelinj.html
These guys do it for $7.50 on just blueprinting.
http://www.witchhunter.com/injectorserv1.htm
Dixit
Dixit
I just had Cruzin Performance flow my new injectors. They were quick, delivered as promised and friendly. The results were available by email before I received the injectors back. Can't say enough good about them. Very knowledgeable and professional.
dda6987, Im probably going to go with Cruzin performance as well. How detailed were the results? Are they like RCEngineering that show the results at different pulse rates and the flow pattern and the peak and all that jazz?
Here is a sample of RCEngineering's report.
http://www.rceng.com/flowreport.pdf
Or do you have a sample of Cruzin's report? Just want to know how indepth their analysis is.
Dixit
Dixit
Dixit,
The report included: Injector Resistance, Leak Down Test, Spray Pattern, 30 sec pulsed flow delivery in ml, 100ml pulsed volume, 60 second static flow in ml, 100ml static flow. The previous were at 58 psi per my request, the following were at 43.5psi....60 second static flow in ml, and approximate pound-per-hour flow. All flow tests were performed at .7 specific gravity
