Fuel pump hotwire + volt blaster necessary?
Old Jan 14, 2006 | 04:06 AM
Y2K2LS1's Avatar
Default Fuel pump hotwire + volt blaster necessary?
If you wire up a hotwire from the alt, would a voltage blaster even be necessary? What i'm saying is, would the volt blaster add any gains to an already hotwired pump?
Old Jan 16, 2006 | 10:51 AM
Fire67's Avatar
I think your referring to the MSD voltage booster... Or something similar. If its anything like that it will provide voltage above battery level. While the hotwire will only gaurantee battery voltage.
Old Jan 16, 2006 | 09:42 PM
Y2K2LS1's Avatar
No, I'm actually talking about the Casper V-plus volt booster that raises the whole cars voltage at wot, not the expensive MSD or KB fuel pump boosters.
Old Jan 17, 2006 | 01:21 AM
Matt D's Avatar
Retired Street Racer
No, it wouldn't yield enough of a gain. Just get the Casper's Fuel Pump Hotwire Kit.
Old Jan 17, 2006 | 05:50 AM
Y2K2LS1's Avatar
I should have added this is for a Racetronix PNP kit, with the hotwire.
Old Jan 18, 2006 | 12:04 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
It all depends on how close the pump's output is to meeting your fuel requirements at the current voltage level with a bit of a safety margin. A volt-blaster is a good idea but will not net the same gains as a dedicated pump booster.
The Racetronix harness comes with a pump-booster interface point and connector set as standard equipment. It also includes upgraded battery nuts and a body ground cable.
http://www.racetronix.com/product/RX...99-FPWHG-2.jpg
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Jan 18, 2006 | 12:52 AM
LS1-STANG's Avatar
Do these LS1 cars really need the hot wire kits ? do they have bad or poor wiring from GM like the GNs ?
Old Jan 18, 2006 | 01:38 AM
Racetronix's Avatar
LS1TECH Sponsor
They are not as bad as the GNs but they still have voltage loss so the harness does improve pump performance. This benefit increases with the load on the vehicle electrical load and the pump's current demands. The harness also allows a booster to be installed as a PnP upgrade vs. splicing it into the marginal factory wiring.
__________________
>WEB SITE<
Old Feb 1, 2006 | 04:32 PM
1ORANGEWS6's Avatar
Can the harness be bought separately? I have a Walbro 255 and I don't want to splice any wires.
Old Feb 1, 2006 | 05:03 PM
Racetronix's Avatar
LS1TECH Sponsor
P/N 135-F99-FPWHG-2
http://www.thunderracing.com/
__________________
>WEB SITE<
Old Feb 1, 2006 | 05:40 PM
MeentSS02's Avatar
Kleeborp the Moderator™
A bit off topic, but here's a question for you Racetronix...any words on the PnP fuel pressure regulator?
