Fuel problem or Ignition problem
Thank You....
Joe
cruise, or when you are opening the throttle? The latter
would indicate a discrepancy between the speed-density
and the MAF airflow, stumble while you are in unsteady MAP
and come back when the MAF is back online. If it's at cruise
then you have to look at the misfire angle, borrow soneone's
scan tool and see if a single cylinder has a problem. The
other thing it could be is that when you cross fuel trim cell
boundaries, if the trim is grossly different you could have a
momentary stumble until the short term trims come around
to take up any slack. All of this wants more than guessing,
need to hook it up and read the tea leaves.
Thanks again
-2 coils
-oxygen sensors
-egr valve
i changed only the two coils and i still have the problem , !!
any ideas !
i think it's better not to wash the car again !! lol
* What codes (if any) are showing?
* You need to datalog the car when this happening. This will greatly help to pinpoint the problem.
* What mods are done to the car (especially recently)?
There could be countless causes, but don't rule out an electrical problem like a short.
