Picture of Racetronix dual pump harness..super quality.
Originally Posted by TransAm6383
DO they make this for the LT1??? any prices? Id love to get my hands on this.
Simply hook up the factory lines, run the harness and plug in the PnP weatherproof connectors.
http://www.lonniesperformance.com/
A system with dual in-line pumps is available as well.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Is it a nice kit?? anyone have pics of it?
__________________
>WEB SITE<
>WEB SITE<
Originally Posted by TchargedLS1TA
What does the 99+ Dual intank setup look like? Does it still use a "T" ?
All hardware used is capable of flowing everything the pumps have to offer without interfering with the other working parts on the sender. As you can see the outlet on a Walbro pump is very small compared to the fittings used. Some people feel that -8 lines are required but in actual fact they are not. -6 Teflon lines (not rubber) are more than adequate. These systems are currently supporting upwards of 1000HP when properly configured.
__________________
>WEB SITE<
>WEB SITE<
What about fitting a "Y" in there? We have tried with every Y we can find and they all end up pushing the pumps too far downwards to fit in the plastic tanks.
Based on the flow and ID's we are working with here you will not gain much if anything from trying to improve on what we have already done in our kits.
__________________
>WEB SITE<
>WEB SITE<
Originally Posted by Racetronix
Here is a more current version of our FLT1-DP-FPKG equipped with a Hobbs switch assembly. The system is fully PnP. This customer opted to have the lines adapted for -8 supply and -6 return. -6 Teflon is all that is really necessary if you wish to change your lines. Factory lines are good to apx. 700RWHP in a FLT1 car depending on your max pressure, motor BSFC and desired A/F under WOT. Lonnie's Performance can fix you up with one of these.
OK, now im confused..is this YOUR kid or his kit? and also..does it come with EVERYTHING in the pic put together like that or will I have to assemble it? it seems like a bad-*** kit and im sure ill be buying it though.
We supply the harnesses, pumps, plumbing etc. to dealers like Lonnie and they assemble them. Lonnie is a good dealer because he is able to provide sound personalized service in a timely fashion.
__________________
>WEB SITE<
>WEB SITE<
Do you require something other than a 'T'? If so it can be supplied. DP systems can be custom configured to a certain degree for your application.
im just curious to why you all havent come out with something to resolve the problem with the 03-04 system for the C5/Z06
i want to be able to run a 200-250 shot of nitrous on my car and im finding out the max will be about 125 with a boost a pump.... LS2 403 530whp on motor
#32
__________________
>WEB SITE<
>WEB SITE<
#33
We have had a solution for these cars since 2004. Please contact Thunder Racing to see if the C5A system is right for you.
#34
Originally Posted by longrange4u
Hey has anyone installed the racetronix dual pump setup? Pics? Was it hard? What did you have to do to the sender?
I think I purchased the very last dual intank setup directly from racetronix (months and months ago)....anyway its finally going in in the next few weeks(with the hobbs switch)... I think my shop was asked not to post pics of the bucket asmb.... but I can attest to how high quality there products look......
On a different note.....what are the stock lines good for anyway (power wise)
(car will have stock lines dual intanks, fast rails, 42#ers)
I'll post some pics when it goes in in a few weeks
#35
Where can i buy this twin intake pump kit plug and play from? Didnt see it on Racetronix site or on Thunder
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#36
Lonnies carries a system for the F-LT1 cars as well. It is fully PnP.
#37
I just called a vendor and they said the dual pump kit supports roughly 1000 hp
__________________
#38
#40
Yea i found them but they said that these dual intake pump kits require a lot of knowledge on the fuel system so im guessing its a pretty involved install. Can someone fill me in here as to what all is involved?
__________________
