big injectors - problems
Old Feb 20, 2006 | 02:12 PM
Runn's Avatar
Default big injectors - problems
Are there any disadvantages with big injectors...
I´m changing my stocks for #50
Old Feb 20, 2006 | 04:08 PM
618HAWK's Avatar
No reason to if you don't have any mods that require more fuel.
Will not gain any power from larger injectors, put the money towards a power making mod.
Old Feb 20, 2006 | 10:17 PM
Runn's Avatar
Yes i know....
Thats not what i was asking.
Old Feb 21, 2006 | 09:24 PM
red ws6 99's Avatar
If they are msd/holley 50 lb they will be a little bit of work to tune. You will have to adjust the injector flow rate table and the injector timing table (how fast the injectors open.
Gary
Old Feb 23, 2006 | 12:56 PM
Runn's Avatar
OK... thanks for the answers.
Old Feb 23, 2006 | 10:20 PM
Dixit's Avatar
Im going to say that going with larger injectors is going to show some problems on the scans. I just dropped in 60lb injectors with no boost yet and the decels are causing major rich issues because the PCM cant command a low enough injector pulse width. To get around this I need to get a vacuum referenced fuel pressure regulator otherwise the rich decels are going to continue to happen which causes hesitation if I get on the gas during the rich decel.
Dixit
Old Feb 23, 2006 | 11:44 PM
RAACCR's Avatar
50's ain't big...I just ditched a set of 83's for a set of 160's. If tuned properly, there shouldn't be any issues.
Old Feb 24, 2006 | 08:32 AM
Dixit's Avatar
Damn, how are you guys getting these big of injectors to work on NA engines? 60 is pushing it as far as the ECM can command on pulse width on decels and idle.
Dixit
Old Feb 25, 2006 | 01:54 AM
RAACCR's Avatar
Dixit
Not NA, but I don't see how that effects idle nor decel (off boost conditions). Use a boost/vac referenced return style regulator. And, if need be, back down the fuel pressure. IMO, the 58-60# constant fuel pressures come with a tradeoff...injectors flow more at higher pressures, but fuel pumps flow more at lower pressures. If you've got overkill on your injector sizing, back the pressure down...combined with the additional drop from the vac referenced regulator, it should be much easier to tune for better idle & decel qualities.
