Which External Fuel Pump..please vote
not if you buy a weldon.........they are the best!
We run a weldon 2025 on a buddies Street turbo stang...Works flawless with no voltage regulator.
My goal was to have sufficient fuel flow to support my Procharged (F1C) 408 installed in my GTO. However after hearing stories of hot fuel, vapor lock, loud aftermarket pumps etc.... the options I listed on the poll seemed to not get very many positive reviews. Also considering my car is 99.9% street driven, I did not want to put up with any of the down sides to the aftermarket high flow pumps. I decided on a staged dual pump setup utilizing an 8.1L fuel bucket and a Walbro GS340, augmented by a Kenne Bell BAP controlled SX Performance 18203 fuel pump. While some may argue the complexity, I think this system will provide OEM reliability and road manners, yet with upwards of 115 GPH flow capability @17DCV, will more than handle the fuel flow demands when under boost.
Here is a schematic of the install.
Here is how I wired it in.
All the gory details:
http://www.ls1gto.com/forums/showthread.php?t=101701
Thanks for all the input and suggestions...
These pumps have internal checkvalves, are very quiet and efficient.
1 pump can be run for daily driving.
2nd pump can be boost or N2O activated for race mode.
Primary and secondary pumps can be switched for equal run time and diagnostics.
This reduces fuel heating and power demands on your electrical system.
Combine this with our PnP double pump f-body harness for easy installation.
Lonnies Performance stocks these parts and others to complete this system.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Kit requires no cutting of the fuel tank & provides a new return connection.
Numerous double pumper kits have surpassed 900rwhp with none of my customers reaching the limits of this kit.
If anyone has the need for a new application, please contact me as I am interested in developing new combinations.
Why not go to a dual intake fuel pump system like the ones Lonnie sells? They are a return fuel system set up. Just a thought since you are doing this to a 99% streat driven car.
Lonnie's has been making them since Dec 2005.
The GTO DP system is a fairly recent addition.
>WEB SITE<
