Which External Fuel Pump..please vote
Lonnie's has been making them since Dec 2005.
The GTO DP system is a fairly recent addition.
In any case it turned out my net HP goals would have exceeded this mystery setup, which is why I turned to my custom approach.
As for other solutions, the GTO community was scrambling for something plug and play, there just was not anything available two years ago. As the saying goes time heals all wounds, and now there are several options for us.....just a little late for me.
having pretty much wrapped up my fuel requirements I am happy with the final solution, basically an OEM system up until I need more oooooompphhhh!!
watching fuel pressure climb with boost and not drop off at all is a beautiful thing!!
Unfortunately, I am still waiting for some dyno results for this setup. It should be comparable to the other kits I build (F-body & Vette) which have been proven to over 930rwhp with the limits not yet found. I've heard rumor of 980 with one of these setups, but have not seen an actual dyno sheet as of yet. Those of you that have results, please share your results & also forward your car info & pics to me for inclusion in my customer car showcase.
For additional tech info, please give me a call. The best time to reach me is (724)322-8505 7:00pm-11:00pm eastern time weekdays & 9:00am-11:00pm weekends.
This may sound stupid but here it goes....
i have a carb "FRAM" fuel filter around i was thinking about using as pre filter it is 10 microns and 90gph i think it has a paper filter.... use it or dont?
my 1st choice was aeromotive a1000 but price and a few comment online changed my mind any body that ran then for long time or miles?
DO NOT use that filter the carb stuff does not flow nearly enough for inj.
There are many options for you give me a call I will help you with a setup specificly for your application and use.
Nate
http://www.kinsler.com/Cat_31_Web_HT..._screen59.html
Mark Koehler runs this setup on his turbo Trans Am (the Sunset Orange one). He runs 8.0s at 3400 pounds race weight using two of these pumps.
I have personally used the Aeromotive 1000 and Weldon 2024 on the street and burned up both of them. They seem to lock up after getting heated up.
The Weldon can and or could have been rebuilt, I highly doubt the motor locked up since they have a drive coupling that separates the motor from the pump end. The coupler is designed to break when ever contamination is introduced to the pump cavity. The pump end might have been "locked up" but this is easily repaired. The coupling kit is also readily available. Weldon also recommends a little tighter micron rating on the inlet filter -- 40 micron instead of the industry standard 100.
These issues could possibly be corrected just by using their respective pump controllers. The reason most don't have an issue with the Bosch is that it doesn't flow as much the A1000 and no where near what the 2025 flows. This is also why you see them in dual or tandem pump applications where you'll stage them as the load increases. Most never run two at the same time -- otherwise you might end up in the same situation.
As far as cost, if your looking at Weldon, they are the most expensive electric fuel pump on the market. But there is no mystery as to what they will flow and if your a boosted application, then you had better know what your fuel pumps are flowing, especially at your total system pressure.
With many in circulation, they have proven themselves reliable & capable of supporting over 1000rwhp.
Trying to make things as simple as possible with a drop in solution.
Please contact me if I can help you with a fuel system.
