Fuel System Aeromotive
Old 04-13-2006, 06:14 PM
Cobra20's Avatar
Question Fuel System Aeromotive
What do you guys think of using this for a fuel pump http://www.aeromotiveinc.com/pdetail.php?prod=62 and this as the regulator http://www.aeromotiveinc.com/pdetail.php?prod=50 with their fuel rails http://www.aeromotiveinc.com/pdetail.php?prod=59
Old 04-13-2006, 08:18 PM
andereck's Avatar
Are you serious?
A belt or hex drive pump is only for a race car with a front mounted cell. Vacuum from the pump would try to vaporize gasoline if you try to pull it from the back. The "porno" regulator is for very high base pressure settings, up to about 90 psi. It has a tall cap because of the long spring inside. They have fuel rails for most modern efi engines unless you have a gen1 sbc or bbc.
What are you building?
Nevermind, I read your other posts. You're a dreamer and that's okay but don't expect to be taken seriously with a new project idea every day until you do one of them.
Its all good.
