Rail removal
Old Apr 14, 2006 | 12:38 AM
67Firebird455's Avatar
Default Rail removal
Is there an easy way to get the freakin frame rail the ... out of the way to pull the old shortblock out the top (which I am ready to do). It was bad enough having it constantly in the way trying to pull the heads off. I'm SUUURREEE it won't be easy... if there's a way, please someone tell me, I want to install the new complete motor from the bottom and set the freakin rails back in once everything is situated (sensors, etc). Thanks in advance friends...
Old Apr 14, 2006 | 01:14 PM
oange ss's Avatar
frame rail ?
Old Apr 14, 2006 | 03:22 PM
LMAO, I'm a bonehead... I meant to type fuel rail. Man... *embarassed*
Old Apr 14, 2006 | 06:10 PM
oange ss's Avatar
just unbolt, disconnect fuel line and pull it off
Old Apr 14, 2006 | 07:29 PM
I know this sounds ridiculous but how do you disconnect the fuel line?
Old Apr 14, 2006 | 08:18 PM
anarchy99's Avatar
Get the quick disconnect fittings from Advance auto... They come in a packet with several sizes. Or you can use 2 flat head screw drivers... fittings work better though, then just return them with the reciept and get your money back.
