FPR Ports?
Old Apr 14, 2006 | 09:02 PM
Skele4door's Avatar
Default FPR Ports?
I bought a used Speed Inc. fuel system and have a few quick questions about what should be connected to which ports. I believe it is a CAS FPR, but I couldn't find instructions for it anywhere. I am planning on running a single -8 line feeding the passenger rear corner of the billet rails, then a crossover in front and then feed from the rear of the drivers side rail to the FPR. I believe the bottom port on the FPR is for the return back to the tank and I can use one of the side ports for the feed from the rails and one for a pressure gauge, but I just wanted to see if this was the correct routing before I make any more lines. There are a few links to pics below and I'd appreciate any help you guys can offer.
Thanks
http://pg.photos.yahoo.com/ph/skele4...59.jpg&.src=ph
http://pg.photos.yahoo.com/ph/skele4...cb.jpg&.src=ph
http://pg.photos.yahoo.com/ph/skele4...f6.jpg&.src=ph
http://pg.photos.yahoo.com/ph/skele4...65.jpg&.src=ph
Old Apr 18, 2006 | 12:53 PM
Nasty N8's Avatar
Yes that is correct.
Nate
Old Apr 18, 2006 | 05:37 PM
Skele4door's Avatar
Thanks for clearing that up Nate. Time for me to start putting braided lines together
