Nast Billet rails and stock fuel setup??
I got the Nasty rails on the car, and I was wondering if you need an adjustable fuel pressure regulator if you are running the rails to the stock lines?
I'm installing my 402 right now, I got the braided line hooked up to the stock hard line off the Nasty rails, and I turned the key to see my FP, and it was at 50psi. Over about 2 hours is went to about 40psi, is that ok?
What are you guys doing that are running the rails with the stock lines, etc? Thanks for the help!!!!
No need for a reg. it is in the tank. Crank the key a couple of times to ge tthe pressure up. It should be 58-60 running. You added a Walbro 340 into the tank for the new motor correct?
Nate
Nate
Yeah I used the Racetronix 255 plug and play kit with the ability to add a boost a pump later on when I spray the 200 shot.
I just wanted to make sure the regulator was a non-issue before start up. Thanks again Nate!!
