Dual FP users! Question for ya.
Old Apr 20, 2006 | 06:50 AM
SRZ's Avatar
SRZ
Question Dual FP users! Question for ya.
I've got Lonnies fp setup. How much of a difference will this make if any at all? Trying to find out if it's worth converting over to a bulk head fitting then running the -8 feed line or keep it as it was designed and run a quick disconnect off the hardline then run the -8 line up to the inline fuel filter up to the bay. Will that short distance cause a drop in flow or too much strain on the fuel pumps?
I stole this pic but it's best one out there.
Here's mine.
Thanks.
Old Apr 20, 2006 | 08:13 AM
DJ's Z's Avatar
I'm in the exact same boat as you are and considering the same thing...Which direction to go...I also have Lonnies dual intank pump assembly...I'll be watching the thread to see what responses you get. I've been told this set up from Lonnie using the stock fuel feed will be good for close to 1000fwhp with proper fuel rails, injector size and front mount FPR...
Nate may have something we're both interested in if he sells it seperately. A hard line (-8 ?) with the pushlok that we can use coming off the stock pump assembly instead of going to a braided line...that would be the ticket~!
Old Apr 20, 2006 | 09:42 AM
SRZ's Avatar
SRZ
The thing is I've already bought the braided line and bulk head they just haven't been shipped yet. I only thought about it afterwards. Hopefully someone will answer our questions. Lonnie told me same thing as well. I also wondered if the feed tubes connected to the y-block would cause turbulence since they're ribbed. But maybe I'm being to ****.
Old Apr 20, 2006 | 11:45 AM
Blown383's Avatar
On my dual intank pump setup Lonnie welded on -8AN and -6AN fittings onto the stock hardlines comming out of the tank. So Im using -8AN feed from the tank to the filter to the rails and -6AN return.
-B
Old Apr 20, 2006 | 12:24 PM
Nasty N8's Avatar
I would change it to -8 bulkhead for the best flow. The stock tube is going to be a huge restriction to what those 2 pumps are capable of.
Nate
Old Apr 20, 2006 | 12:49 PM
SRZ's Avatar
SRZ
-B
Did you ask him to do that? I am sure you paid extra for that too right? That's busted as I ah never mind..........
Old Apr 20, 2006 | 02:58 PM
Blown383's Avatar
Im not sure... I bought the kit NIB from another list member off of Camaroz28.com and thats the way it came. I'm just going to leave it that way because it would cost me at least another $50-60 to switch over to a bulkhead fitting to connect to the -8An feed line.
-B
