Cleaning injectors
Old May 3, 2006 | 07:54 PM
muncie21's Avatar
Default Cleaning injectors
I just picked up a set of SVO 42lb'ers. They look kinda grubby. Is it worthwhile to soak them in a solvent (carb cleaner, gas, etc.) to clean them out before I put them on?
Old May 20, 2006 | 10:41 PM
SSmokin 01's Avatar
I would'nt soak them. You can clean off the exterior of the injector if your just looking to clean them up.
If you think there something wrong with the flow, you'll need to send them out to be cleaned and checked internally.
