Stock Fuel Pump Limits
1 Post
Originally Posted by JerikSS
I plan to run 8psi with 42lbs injectors. I currently have a cam and heads in the car. The question is, will the stock fuel pump hold?????
I just bought the racetronix kit that I should of bought in the beginning im just hopin the 42# will make it to 550rwhp, this turbo stuff is really expesive....does everyone else think I will make it.
With enough pump you'll make it just fine.
You might consider tuning your system for lower than stock pressure first before adjusting for boost.
Keep in mind your pumps volume capacity is increased at lower fuel pressure.
Another way to up the volume from a pump is to increase the voltage.
