return line
Old May 12, 2006 | 08:49 PM
01350ss's Avatar
Default return line
i have an '01 ss. These cars have return fuel lines correct? Under the car where all the metal lines are: some small brake lines and 2 larger lines. Those larger lines are fuel feed and return right?
Or is one line a feed and the other for fuel vapor. (it looks like the 1 line goes to the evap solenoid on the intake)
I ask because I need to relocate those lines away from the exhaust
Old May 12, 2006 | 09:12 PM
ujslost2's Avatar
One is for the main feed line and the other is for the evap system. Some do away with the evap.
Old May 12, 2006 | 09:31 PM
Syxx613's Avatar
is it the same for 98's?
Old May 12, 2006 | 09:34 PM
227Hawk's Avatar
You can use the evap & overfill as a return system
Hawk
Old May 13, 2006 | 12:04 AM
slow's Avatar
all LS1 f-cars have a quazi return system, with a loop at the back of the tank, and a single line feeding the motor.
... you can use other lines for return, or a set of V6 lines only costs about $60 at the dealer, with full length return line, and no T
Ryan
Old May 13, 2006 | 12:19 PM
lechner80's Avatar
Sorry to but in on the thread, but could you or someone give a little guidence on removing the evap system. I have a LS1 out of a 2002 TA that's going into a 56 corvette. I have all the stock lines and pump from the TA but was planning on using the fuel filter/regulator from a 99 vette for the conversion. Any help would be great. Thanks John
