?? on injectors and fuel pump
Old May 22, 2006 | 10:25 PM
1999TransamWs6's Avatar
Default ?? on injectors and fuel pump
looking to make between 500-600 RWHP on motor and another 300-400 on spray what type of fuel (12:1-13:1 CR) And what injectors and pump should I use. (I will have a stand alone for the nitrous). I have a 255 racetronix pump and 42 #'s Should I go bigger????? What do you guys think?
Old May 23, 2006 | 01:06 AM
Nasty N8's Avatar
Your pump and injectors should be suficent for your motor hp and with that CR you will need to run 100 octane.
Nate
Old May 23, 2006 | 05:06 AM
JMBLOWNWS6's Avatar
Or you can run a mix of what ever octane is available to you and mix it with motorsport 109 by vp. Thats what I do. The 42's should be fine.
Old May 23, 2006 | 07:14 AM
Thanks guys I guess ill leave them in and check the duty cycle.
