fuel set up questions
Old May 31, 2006 | 10:18 AM
tuske427's Avatar
Default fuel set up questions
HI:
I have a '99 (vette) LS1 that's going in an old hot rod.
I've installed an in tank fuel pump for this and am wondering about the fuel rails on the engine itself.
1- The "pusle regulator" has a tube off the end- I'm assuming a vacuum line? I have not seen this open tube on any other regulators. Should this be hooked up to the intake manifold for vacuum?
2- I've read that "99 and newer" are the "returnless" fuel systems, yet there's a second smaller fuel line. Is this a vapor line for the emmisions? DO I still need this hooked up or can I block it off? (I'm guessing no, I need it) I'm not going to run emmisions on this car.
3- Assuming I do need the vapor line hooked up- can this just go straight back into the tank itself?
4- as for pressure regulator- I can use a GM fuel filter with the built in regulator, yes? any idea on part #? This also has a "return" line that needs to go back to the tank (so I'll have 2 return lines)
Any help would be greatly appreciated.
Thanks,
-BV
Old May 31, 2006 | 10:29 AM
Nasty N8's Avatar
If the rails themselves only have one fuel hookup there is no need for the vacuum line.
There is a smaller line wrapped up in the heat tape but it is a vent from the tank. You can use it as a vent or just plug the intake.
No need
The 99up Vette filter has a built in regulator it does have a return line but thats the only return line you need?
Nate
Old Jun 1, 2006 | 10:06 AM
tuske427's Avatar
There's the 2 lines from the fuel rails. I believe 3/8 and 5/16th. The smaller should be the vent line, yes?
The pulse regulator has a vacuum line on it, yes. I have circled it in the pic.
So I can just unplug this?
Old Jun 1, 2006 | 11:49 AM
Nasty N8's Avatar
Nope that looks like a return set of rails from a 97-98 Corvette. The smaller one is the return line and the vacuum may just be an adjustable reg. that could go to boost ref. Pic is hard to tell but it does look to be that way.
Nate
