How Do You Test Injectors?
Some poeple. If you want to do it the right way take them to someone who can flow them and rebuild them.
No wonder your not getting any help. so get you an air tank, take off your fuel rail w/injectors installed (completely off of the car)
DO BE CAREFULL ON DOING THIS
but hook up the air tank to the driver side port on the front of the rail, slowly let air pressure in, just slightly open the air tank. and take a 12v battery of somesort, or run wires from your car battery and probe each side of the 2 prongs on each injector and you should hear them hiss.
i bought some racetronix 36.5#ers and 1 of them was being 'sticky' and not wanting to work, so we started doing what i listed above and found that 1. then we pestered it and pestered it, hell we even banged it one time and then it worked fine and still is
Hey I really appreciate that. Makes sense. I'll give it a shot.
I sure as heck don’t want to connect 12v to my injectors if there is continuity between the two prongs…..
