injectors....................?mega squirt, E85, 150lbs
ok i have a gen 1 small block with twin masterpower T-70's on it and a megasquirt ecm (bank fire).
do you think if i run 92 oct. FMS 150lb injectors ill have any problem with it loading up at idle?
and will they work ok if i were to run E85?
a few guys have used 150s or 160's in there street cars.
might take a little while to get the idle right
you could ask the guys on the mega squirt board on how well they are getting them tuned.
parish had 96lb'ers on his megasquirted truck
mike brown has 160s on his BS3 controlled 2002 CE that streetable
thanks smokinhawk i guess i just wanted to know if it can be done, and few other people said they run them so im going to give them a try.
maybe ill be able to make 1000fwhp on E85 which would be cool
