Fuel pump choices for a 1998 FBody...?
What about the Hot Wire kits I've seen? Is the stock wiring that crappy that it cant be trusted with a higher volume pump?
What is the difference between the Racetronix 98-99 kit and the 00+ kit?
My future goal is around 475rwhp, so what type of fuel system would be recommended?
Thanks!
Nate
a hotwire kit doesn not "convert" anything..
the stock gauge wire is very small for the current draw of the fuel pump. this causes the voltage to drop.. so if the SYSTEM voltage was operating correctly at its normal voltage of 13.5, you can see as little as 11.5 or less with the walbro running.
all the hotwire kit is, is a thicker wire, and a relay to click it on. very simple but highly effective.
I think the Racetronix and the 42s are a good setup that will handle the power I will want to make.
