Need brainstorming help...
Old Jun 16, 2006 | 03:21 PM
Camaro_freak's Avatar
Default Need brainstorming help...
What would cause the PCM to stop making fuel corrections? When I start the car, it goes into closed loop as it should, O2 sensor readings are jumping up and down between 0 and .9V. The car driveability is not perfect though, as the throttle response is somewhat "sluggish", and the car bogs and surges slightly at part throttle. After driving for awhile, I'll notice the car driving more smoothly, so I check the O2 sensor readings, and they're staying around .9V, and the STFT's are locked at 0.00 for both banks. What could be causing this? The O2 sensors have about 3000 miles on them, and it acted like this even with the old ones. It seems that my VE may be off since my LTFT's are not that close to 0 under most driving conditions. I have no trouble codes at all, so this is pissing me off. This is an OBD2 LT1 by the way. Any ideas???
